LR3 Catalytic Replacement
Old May 17, 2016 | 11:10 AM
houm_wa's Avatar
...only thing missing is the MAF Sensor and Throttlebody cleaned.
(not trying to patronize you, your experience sounds painful....but it's worth one last shot, especially since cleaning the MAF and TB is cheap 'n easy)
Old May 17, 2016 | 11:37 AM
samnt650's Avatar
I did the cleaning already and didn't resolve the problem. Searched the web, I'm not the only truck running into the Cat Code 2096 & 2098 issue. However none of the post provided a remedy.
I'm going to replace the MAF but doubt this will resolve the lean running issue.
Old May 17, 2016 | 04:58 PM
BritishautoworksSD's Avatar
Fuel Trim checked? What are the fuel trim readings?
Old May 17, 2016 | 08:16 PM
DavC's Avatar
Originally Posted by samnt650
Was scanned by LR dealer computer. He works at local dealer and seeing a lot of the 4.4L getting new cats. My cat failure is 1.5 yrs in the making. I had one of the code for a while and finally both codes appeared.
Thank you for clarifying that was the case.
Old May 18, 2016 | 09:21 AM
samnt650's Avatar
Interesting developing... (1) Truck is throwing P0420 & P0430 code. (2) MagnaFlow is out of stock with LR Catalytic Converter until late June / early July... Is that mean "a lot of" LR & RR replacing the Cat? Hmmm
Old May 18, 2016 | 09:41 AM
P0420 and P0430 are the dreaded cat faults. Each one is just over $1000 new from the dealership. Driving with these faults doesn't harm the vehicle. Just prevents you from passing a smog emission tests, especially in California.
Old May 18, 2016 | 11:19 AM
samnt650's Avatar
cost half with the MagnaFlow 48 State Cats. A little more w/ the 2 State Cats
Old May 18, 2016 | 11:23 AM
Wow... I looked at the Magnaflow website. They don't list a California Cat for the LR3. Do you happen to have a part number?
Old May 18, 2016 | 11:42 AM
samnt650's Avatar
Dont know CA but there's something funny about selling / installing Cat in NYS, where I'm getting the parts from..
Old May 21, 2016 | 09:05 PM
EastCoast's Avatar
Not that anyone would have done this but will the o2 sensors read fine if the cats are gutted?
