LR3 DSC on sharp curves
Old Sep 22, 2013 | 09:56 PM
jafir's Avatar
Default LR3 DSC on sharp curves
So the last couple of times I drove my LR3, I noticed that on certain sharp turns, always left, the DSC triangle warning light comes on and I hear the ABS modulator doing its thing.
On Friday I had a local shop replace the lower control arms and as part of that they did an alignment. This kind of has me thinking Steering Angle Sensor. I just did a calibration using my hawkeye, but I haven't had a chance to drive it since.
Are there any other things that come to mind that could set off the DSC warning?
Also, if it IS the steering angle, what OTHER symptoms might that generate? There reason I ask, is that on Saturday I also towed a trailer for the first time (with the 90 on the back of it), and I noticed a weird sway from the LR3 kind of a rocking from the front left corner to the right rear corner. I was kind of thinking it might be warn out shocks, but now I'm wondering if maybe this might be a symptom of the same issue?
Old Sep 23, 2013 | 02:25 PM
houm_wa's Avatar
If you want to see if your shocks are worn out just put it on a lift and look for contact between the upper control arms and the shocks. If the your steering angle sensor were out-of-whack you'd likely get faults...I've had SAS issues in the past and it has cause faults. Could the DSC be engaged due to sharp cornering on worn tires? How many miles on your Michelins?
Old Sep 23, 2013 | 02:51 PM
jafir's Avatar
I'll look into that. I don't have Michelins, I've got some cheapo nexan tires. They are pretty worn, and not evenly due to the lower arm bushings being worn out.
Old Oct 1, 2022 | 05:30 PM
1888's Avatar
I know this was a long time ago but what did it end being? My 2008 lr3 just did this today on a left hand turn.
Old Oct 1, 2022 | 05:39 PM
jafir's Avatar
I think new tires fixed it, but it’s been a few years and I had two LR3 in that time, so I may be confused.
Old Oct 1, 2022 | 09:30 PM
1888's Avatar
Dang, my tires have less than 10k miles on them. I don't think thats my problem, im wondering about a wheel speed sensor. Thanks for replying, if figure it out I'll post it here.
Old Jun 14, 2024 | 06:56 AM
kels83's Avatar
Adding that I had this unwanted DSC light flashing on curves when the vehicle was warm. It started after replacing my front and rear diff oils, filling to spec of .61 L in the front and 1.6 L (locking) in the rear. I felt like mine was coming from the front, so I did another drain/fill, but I read about the capacity and this time I filled until fluid ran out the drip hole. I also unscrewed and cleaned all the wheel speed sensors (very easy from under the vehicle, no need to remove any other part) on all 4 corners and cleaned the sensors with electric cleaner.
I took a long drive with sharp turns yesterday and had no issues at all for the first time in a month. Not sure which one of these was the fix, but thought I'd add to the knowledge here.
ELambo
Mar 8, 2022 07:15 PM
spannermonkey
Mar 25, 2019 06:05 PM
moorebl
Oct 3, 2014 09:59 AM
jimyal
Nov 5, 2011 09:44 AM
escobarIV
Jun 8, 2010 07:57 PM
