LR3 ECU Problem ! Please help !!!
Hi All
My LR3 is work prefect until last Saturday , It stopped suddenly and I cant start any more , we have check the ECU though the computer , and found almost all ECU report fault at 1 time !
We have check the battery and connector , both work and look ok.
Please help and suggest anything I do try ?
if we need to replace , how to replace ?
Please help !!!
Thanks
Please help !!!
Thanks
Water is a great place to check, but to have all light instantly and no start I'd start with an old battery not capable of supplying proper voltage. More information. Where are you located?
(To be clear, did you replace, test, or just check battery voltage? If it isn't supplying enough power when you try and crank it a bunch of false codes can come up.)
Was the engine bay recently soaked somehow?
Hi All
Thanks for your advice but I still cannot solve the problem.
Therefore I sent my car to workshop and they show me the following pic and told me the engine was totally dead ......
And now the workshop just suggest me to gave up the my car...
Please let me know is there any way to repair the engine or can I source the recondition engine (mine is 2.7L Diesel)
Please help...as I am really hopeless at the moment
Thanks a lot
Thanks a lot
Paul Grant
08-10-2014 12:29 PM
