LR3 Electric Parking Brake Intermittent Issue
Old Jul 5, 2022 | 08:43 AM
  #21
lenzda's Avatar
This is still on my to do list. Any recommendations on parking brake fluid? I know it needs to meet DOT 4 spec. I can't find the Castrol brake fluid locally. Prestrone, Valvoline, and Pentosin are usually what's available.
Old Jul 5, 2022 | 10:46 AM
  #22
douglastic's Avatar
I use Pentosin DOT4 LV
Old Jul 5, 2022 | 10:49 AM
  #23
DakotaTravler's Avatar
my parking brake uses no fluid.
Old Jul 5, 2022 | 10:58 AM
  #24
lenzda's Avatar
correct. i don't think it's a parking brake issue as suggested further up in the post, this seems to be a brake caliper issue. Would still take suggestions on brake fluid suggestions.
Old Jul 5, 2022 | 11:00 AM
  #25
lenzda's Avatar
i misspoke as i was typing stream of conscience style. by parking brake fluid, i meant brake fluid. rookie mistake
Old Jul 5, 2022 | 06:28 PM
  #26
Anything DOT 4, that's all you need to know. DOT 4 is a standard, so as long as it meets that you are fine. From cheap to fancy, its all the same.
Old Jul 6, 2022 | 07:51 AM
  #27
lenzda's Avatar
Should I drain the whole system, or just replace with what I lose when replacing the rear rubber brake lines. Any issues with mixing brands (not sure what is currently in there)?
Old Jul 6, 2022 | 11:26 AM
  #28
douglastic's Avatar
always bleed out old til you see 100% new clear fluid at each corner, with no bubbles
keep reservoir full of fresh fluid so you don't introduce air there either- filling as you pump
then top up to level
k2dhnc
Jan 18, 2022 03:29 PM
The_OGCJR
Aug 31, 2021 07:04 PM
jbullock78
Apr 15, 2019 02:32 PM
NJHokie
Mar 14, 2013 09:41 AM
