LR3 LR4 RRS DIII Differentials
Old Sep 8, 2014 | 09:38 PM
  #21
unseenone's Avatar
Thanks for your service!!!
Old Sep 9, 2014 | 04:41 PM
  #22
MoShadeTree's Avatar
Only because I don't understand the complications of over fill but, I replace the oil in the front diff 2x so far and once in the rear. The front @ 95 and 105. The rear @ 105. @ 95 The front was dark and the drain plug was full of metal fur. @105 it was dark and just a little fur. The rear was super black and I could actually see the metal flakes in the oil.
I just filled them with Mobil 1 Syn gear oil and filled until it came out the hole. Am I missing something serious or is this another LR engineering Vs real world thing? You know - measure and refill, although, nothing bad fill happen if filled to the fill hole.
Oh Yeah, I started replacing the oil in the front because I felt a slight grind/whin. It really didn't go away with the oil change, but it surely needed changing. I'm now changing every 2nd oil change.
Old Sep 22, 2014 | 11:17 PM
  #23
K9Hexe's Avatar
Thank you for the kind words. It was an honor to serve with my K9 at my side. She did all the work and got me home in one piece.
Old Oct 8, 2014 | 10:58 AM
  #24
kram's Avatar
Hi unseenone,
Can't PM, as this is my first post! I'm also in Austin, and own a 2006 V8 SE LR3. For a couple of years it's had some driveline noise that varies with road speed, not engine speed. It seems to be getting slowly worse. How can I narrow this down to a specific area? I suspect one of the differentials, but it's hard to prove. Also, do you have a good shop here in town that you'd recommend for diff / gearbox work?
Thanks!
Old Oct 8, 2014 | 11:08 AM
  #25
unseenone's Avatar
Yup-- I can help you. I sent you a PM.
Old Oct 8, 2014 | 09:35 PM
  #26
TOM R's Avatar
While you are in there disconnect and blow out the vent , dealer tech told me they clog easy causing problems
Old Oct 14, 2014 | 09:31 PM
  #27
TOM R's Avatar
How are you guys making out with the r/p in transfer and diffs?
Btw dealer tech told me do not fill as the manual says, fill till it pours out just like any other diff so...
Old Oct 14, 2014 | 10:07 PM
  #28
unseenone's Avatar
A couple of years on and all is good with RP.
I stick with the initial fill amount on new fills, and the recommended change amount, maybe a hair over, never under.
That's your dealers opinion, that's not official, and based on my experiences with them, it doesn't mean much.
Old Oct 14, 2014 | 10:11 PM
  #29
jafir's Avatar
I asked a dealer tech that same question and he said he always fills lr3 until it pours out, and has never had one come back. He says that BMW powered L322 range rovers will puke oil out the breather of the front diff if you fill them that way. Perhaps that's why the manual says to not do it.
Old Oct 15, 2014 | 07:05 AM
  #30
TOM R's Avatar
Well I did the back rear yesterday, it took less then 1 1/2 qts not overflowing,probly closer to 1 1/4 it was humming some and had little fluid in it and a leaking pinion seal
Still need to do the front , guess I need to do the transfer case too
50k mile vehicle and **** is bad, pathetic ESP. For what these cost new
