LR3 no start-insane
Old Jan 12, 2025 | 03:24 PM
houm_wa's Avatar
The key (lack of) functionality is strange for sure, and is maybe a separate issue from the no-start issue. Once you have a physical key in the slot, though, shouldn't it start? I guess I'm saying....key issues aside, have you ruled out the starter?
I'd also be looking for water ingress and faulty wire connections. Even rodent damage to the wires. You mentioned the use of a GAP tool in your post, do you own one, or was it in use at the shop you took the LR3 to? If you don't own one, you should get one. Then you can read the codes and report them here. That would help us help trouble shoot.
Old Jan 13, 2025 | 09:54 AM
Gnomadf's Avatar
Physical key won't do it. It will turn the dash and accessories on but when you turn it to start it don't turn over. And from what the OP says I wouldn't rule out a bad cluster.
Old Feb 26, 2025 | 05:18 PM
WeBeCinya's Avatar
Closing this one out. After a couple months wait, here was the resolution.
Shop plugged up Land Rover software, a few lost communication codes from software to bcm. Common with cluster issues.
Ordered genuine key and sent cluster to clusterfix.net for repair. This company came highly recommended as the cluster can cause many issues and they fix them all during their repair service. Cluster repair was $400. New key $500.
Knock on wood we are good to go.
For the record, this 3 has been maintained well. Receipts prove that. But I can’t fault the prior owner for not “maintaining” his cluster.
link to cluster fix
https://clusterfix.net/store/
What a mess! Glad to have it back!
Old Mar 4, 2025 | 11:03 AM
WeBeCinya's Avatar
Welp not fixed. Went out today to drive same symptoms. It’s like the car has lost the keys again and the red blinking immobilizer light will not shut off. Both newly programmed brand new Land Rover keys will not unlock it or show any recognition to the car.
Totally stumped and it seems the shop that I have it at is as well. Has anybody ever seen this before?
I would assume the only other part that has not been replaced Here is the body control module.
Old Mar 6, 2025 | 12:25 PM
P-Bod's Avatar
I hope you get to the bottom of this. I know it is extremely frustrating.
The cluster is one of many components on the network, and it seems our LR3’s are highly intolerant of anything dropping out. In my case, an intermittent no-crank ended being solved by the clusterfix repair. Other components including the HVAC control module can cause the same problem. This YouTube is the best thing I’ve seen in what it takes to drill down to the root of a network failure. Obviously it will take a ton of patience.
donniefitz2
LR4
May 22, 2025 05:27 PM
AndrewGr
LR4
Sep 24, 2022 01:45 PM
TheGreatSantorini
LR4
Jun 10, 2021 11:40 PM
Amiee Pentzer
Range Rover L322 (3rd Gen)
Apr 1, 2020 11:04 AM
charles_h
Nov 13, 2007 03:50 PM
