LR3 p1070 code
Old Jul 3, 2020 | 11:38 PM
Miki Repac's Avatar
4wd High
Cool LR3 p1070 code
Just got P1070 code on my LR3 HSE and starts stuttering when under stress. Anyone had this issue?
Old Jul 4, 2020 | 09:31 AM
DakotaTravler's Avatar
Clean the MAF sensor and clean the throttle body. Check for vacuum leaks. Replace upstream O2 sensors.
Old Jul 4, 2020 | 07:23 PM
Miki Repac's Avatar
4wd High
Ok,
I have done cleaning MAF and Throttle body but have not check O2 sensors. I will do that and i will check fuel pressure as well.
thanks
Old Jul 5, 2020 | 11:01 AM
douglastic's Avatar
Did you mean P0170?
FYI - sometimes cleaning MAF doesn't help, especially if it is 120k+ miles
A new OEM MAF sensor (don't buy cheap) fixed mine - changed after new OEM PCV valve was installed
good luck!
Old Jul 5, 2020 | 11:53 AM
Blackngold77's Avatar
Chased one for a few months recently. Tried a TB gasket, came back...tried cleaning the MAF, came back.
Gave up and got a new Denso sensor, fixed it right away.
No more sluggishness no more codes.
They aren't terribly expensive either, got it for $100 on Partsgeek. Part number on the site is
18855-08041522
Old Jul 6, 2020 | 08:38 AM
Miki Repac's Avatar
4wd High
Thanks for tips everyone,
I did replace PVC valve and Coil/spark plugs few months back. I think I will order the MAF sensor first and see will that help, if not I will get O2 sensors.
I will let you know the results.
Old Jul 6, 2020 | 08:43 AM
Miki Repac's Avatar
4wd High
Yes, p1070 fuel bank 1 fault and it comes back after15 min of driving when I clear the code.
Old Jul 6, 2020 | 10:17 AM
douglastic's Avatar
You might want to also try a Throttle Body Adaptation (reset) to zero out your baseline
Opening up and cleaning/fiddling with the TB could have left it in a position it is not expecting
Old Jul 6, 2020 | 10:39 AM
Miki Repac's Avatar
4wd High
It ran fine for a while after I cleaned it and I knew not to move it manually for that reason but I could have bumped it or something to trow it off. how do you reset it?
Old Jul 6, 2020 | 11:32 AM
douglastic's Avatar
with a diagnostic tool like IIDtool from GAP or similar
not sure if the “hard reset” via battery cables will do or not - someone else may chime in
