Lr3 radio
Old Dec 27, 2020 | 04:07 PM
Oceanguy33's Avatar
Default Lr3 radio
I’m looking to swap the lr3 radio with another of the same from a RR sport.
Do I need to reprogram or is it plug and play?
(the head unit has no sound - very intermittent, and the right **** will not adjust any of the balance/fade/bass/treble functions)
Old Dec 28, 2020 | 04:36 PM
DakotaTravler's Avatar
You can just swap em, no programing needed. Also it could be the AMP, the radio on these are for the most part a dummer controller, the amp does the heavy lifting.
Old Dec 28, 2020 | 08:47 PM
Oceanguy33's Avatar
thanks. I thought as much.
can I use an amp from a 2009 rr sport with the same HK set up with the MOST connector? Am assuming the amps were pretty much the same for the run.
Old Dec 28, 2020 | 08:49 PM
Best to match amps, there are a couple variations. Logic 7 or not, etc.
Old Dec 28, 2020 | 09:00 PM
Oceanguy33's Avatar
Ok. Does it need a re program. Or much like the head unit. No issues?
Old Dec 28, 2020 | 09:03 PM
Nope, just swap and you are good.
Romelo357
Oct 7, 2018 02:12 PM
Glen11
Apr 16, 2014 06:40 AM
Glen11
Apr 16, 2014 06:15 AM
cnazario
Jul 17, 2012 04:02 PM
smithwick
May 21, 2008 07:16 PM
