LR3 Radio Replacement... Help
Old Mar 19, 2013 | 12:55 PM
cnazario's Avatar
6th Gear
Cool LR3 Radio Replacement... Help
I have a V-6 LR3 with the standard radio (CD-400) which the button's are falling out... I decide to replace with the same year 6 CD Radio (CD-465) that I bought thru eBay...
I manage to install the radio, all plugs plug right into... but I notice that I am missing one (Fiber-Optic's)??? It does power up , but I am unable to change the radio station, nor the Volume works...
Any Ideas?
Old Mar 19, 2013 | 01:14 PM
Rovin4life's Avatar
you have one with an amp. and adding an amp won't work cause you can't add it to the system. it won't read.
Old Mar 20, 2013 | 09:21 AM
cnazario's Avatar
6th Gear
Question
Even if am installing a factory LR3 6 CD-Radio (CD-465)?
Old Mar 20, 2013 | 09:58 AM
unseenone's Avatar
I couldn't swear to it, but I also believe you will have to program the vehicle to recognize it as well. I am not sure about the amps.
Old Apr 3, 2013 | 09:36 AM
roverguy7's Avatar
it will not work with out a good amount of wiring and other componants. the 6-cd system uses a fibre optic MOST ring to transfer audio signals to the amplifier, neither of which your vehicle has.
Old Apr 3, 2013 | 01:29 PM
gprtech's Avatar
Augh! MOST(Media Oriented System Transport)! I worked for Mercedes for a year (around 2003) and they used the MOST system. To say it sucked would be paying it a compliment.
MOST is a fiber optic based network that requires that the network be configured to recognize what components are installed. Even if you replace a component in the system, the system needs to be configured to recognize the replacement component.
Even then, since the components were all made by different manufacturers, there were often problems, and the vendors all pointed the finger at someone else.
I would ditch the head unit an get an aftermarket one.
Old Apr 10, 2013 | 06:53 PM
khronus79's Avatar
4th Gear
It will work, you need a faultmate and head over to DISCO3.CO.UK - View Forum - In Car Electronics (D3) , ask your question there, they'll point you in the right direction
dogstarsix75
Apr 24, 2020 01:33 PM
nh9095
Jan 14, 2019 12:36 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
VB_Rover
Oct 19, 2005 12:25 AM
