LR3 roof leaking
Old May 17, 2021 | 10:05 PM
Charliegeosci's Avatar
Default LR3 roof leaking
Hi I've got a 2006 LR3 HSE 4.4L V8. It appears that the rear roof glass is leaking on my truck. Not the sunroof, but the aft section of glass. Any tips on this? A shop once said they performed a test on the tubes and said it was fine, but it was also a questionable shop, so idk. They said it didn't leak. But its like every time I go through a car wash (I don't anymore because paint) it leaks and can just like start raining inside the car. Help pls?
Old May 17, 2021 | 11:45 PM
Blackngold77's Avatar
It's the seal around the 3rd brake light.
It's sealed in place like a windshield, so an old one can dry, crack and let in water. Also the 3rd brake itself could be the culprit if cracked
Old May 18, 2021 | 06:41 AM
nice, I figured it is an actual glued seal. Any links to diagrams for this or any videos?
Old May 18, 2021 | 08:15 AM
May not be the recommended method but this video gives a way (only if you get a new light)
Most people get the light replaced by a glass shop. I believe you can put some sealant around it without taking it out but dont quote me on it
Old May 18, 2021 | 10:54 AM
https://youtu.be/KXrumW_nztg
So it actually leaks from the front section of the glass roof, just over the 2nd row. Do you think it still could be this light/seal leaking?
Old May 18, 2021 | 11:27 AM
Ah, that's probably something different then.
Either the rear sunroof drains or the glass roof itself
Old May 18, 2021 | 12:15 PM
so are there diagrams of how the roof drains are routed? If it’s the roof itself, I could just ask any glass shop to re-glue it? I wouldn’t want to risk prying that $1800 piece of glass off myself, lol.
krick3tt
Nov 11, 2020 08:14 AM
WakyKavaky
Sep 20, 2020 08:56 AM
LR3Philly
Jul 6, 2014 02:23 PM
abqrb2000
Feb 8, 2014 10:02 PM
mhaise57
Sep 7, 2009 08:34 PM
