LR3 Seats Won't Fold Down Flat?
Old Apr 15, 2021 | 12:17 PM
Mary High's Avatar
Question LR3 Seats Won't Fold Down Flat?
I have a 2006 LR3, and the middle row of seats do not fold down flush with the rest of the cargo space. I have watched multiple youtube videos on how to get them to fold down, but still having no luck. This sounds silly but are there certain LR3's that don't have this feature? Or potentially a mechanism that could be jammed?
I don't have the full user manual for this vehicle, as it was lost in the aftermath of a previous owner's wreck, so I am flying blind!
Trying to get them to lay flat so that I won't have to build a platform for camping this spring!
Old Apr 15, 2021 | 01:03 PM
nevillusa's Avatar
I don't know if these seats were ever designed 'not' to fold flat.
Have you tried the following - Underneath each seat, middle, front, there should be a black strap which is about 3 inches long. It hangs down towards the floor, so may not be immediately visible. Find this, for each of the 3 middle row seats. It is spring-loaded. Pull it, exactly horizontally. I.e. towards front of vehicle. This should release a 'catch', which then allows you to pull the seat slightly forward, and push it down to it's lowest point. You should hear a 'click', when it has reached it's lowest point. Pull it again, to release the catch, to move the seat back up again.
If this doesn't work, there is probably something wrong with the strap/spring/catch mechanism. In which case, fold the seats forward, from the top, so that you can see the whole mechanism, on the underside and below each seat, in order to diagnose.
Old Apr 15, 2021 | 09:34 PM
loanrangie's Avatar
Some early 5 seater models wont fold completely flat but will tilt forward instead.
tayken
Dec 16, 2012 07:22 PM
carobin
Nov 17, 2010 09:39 AM
Kenbeck77
May 31, 2009 05:04 PM
Dan_da_LR3_H2_man
Nov 1, 2008 10:17 PM
4banger77
Aug 3, 2008 02:37 PM
