LR3 Suspension Valve Block Removal and Cleaning
Hi guys,
I noticed my front suspension drops overnight, and I'd start with cleaning the valve blocks, didnt really find any DIYs of removing the valve block. So I ll ask here.
1. Do I need to remove front wheels to let the suspension hanging free, or it doesn't matter if the wheels are on the car or not?
2. I persume the process is just removing the 3 air lines slowly and take it out?
3. Do I need to unplug the battery or pull out fuse F26E?
4. What should I do after replacing it to re-pressurize the system?
Much appreciated!
Much appreciated!
I replaced mine recently. Removed the right front wheel and let the suspension hang on the strut. I slowly disconnected the airlines to de-pressurize. I did not unplug the battery of pull a fuse. I put it all back together and dropped the truck back on the ground.
Started it up and let the compressor run for a few minutes. Before it posted any warnings, I turned the truck off and let it cool for 10 minutes. The 2nd time I started it up it was back to normal.
middleman496
12-30-2009 03:17 PM
lewis051184
04-02-2009 08:18 PM
raid13
01-13-2008 07:38 PM
tuwrx
12-15-2007 12:16 AM
raid13
06-16-2007 08:13 PM
