LR3 Suspension Valve Block Removal and Cleaning
Old Mar 31, 2015 | 10:32 PM
redbadge's Avatar
Default LR3 Suspension Valve Block Removal and Cleaning
Hi guys,
I noticed my front suspension drops overnight, and I'd start with cleaning the valve blocks, didnt really find any DIYs of removing the valve block. So I ll ask here.
1. Do I need to remove front wheels to let the suspension hanging free, or it doesn't matter if the wheels are on the car or not?
2. I persume the process is just removing the 3 air lines slowly and take it out?
3. Do I need to unplug the battery or pull out fuse F26E?
4. What should I do after replacing it to re-pressurize the system?
Much appreciated!
Old Apr 1, 2015 | 10:33 AM
morrisdl's Avatar
I replaced mine recently. Removed the right front wheel and let the suspension hang on the strut. I slowly disconnected the airlines to de-pressurize. I did not unplug the battery of pull a fuse. I put it all back together and dropped the truck back on the ground.
Started it up and let the compressor run for a few minutes. Before it posted any warnings, I turned the truck off and let it cool for 10 minutes. The 2nd time I started it up it was back to normal.
Old Jan 23, 2017 | 11:29 PM
JDoubleDuBB's Avatar
7th Gear
Out of curiosity, did removing and CLEANING your Valve Block help and/or fix the issue? If so, how did you go about cleaning it? I'd be curious to try this before actually replacing the unit.
middleman496
Dec 30, 2009 03:17 PM
lewis051184
Apr 2, 2009 08:18 PM
raid13
Jan 13, 2008 07:38 PM
tuwrx
Dec 15, 2007 12:16 AM
raid13
Jun 16, 2007 08:13 PM
