LR3 Tail lights inoperable
Hi all,
I am having a strange issue with my 2006 LR3 which I cannot chase down, hoping someone here has some insight.
As the title says only my tail lights are not working. Brake lights (all three) are good, reverse lights function, headlights low and high both work.
No dash lights on, break switch replaced, all new factory bulbs replaced, checked literally all of the fuses at this point. Opened up the cable chases and can’t find anything broken off anywhere. No codes with GAP tool.
Anyone have any thoughts? Driving me nuts!!
I do have 12v at the center side of f15 with the fuse pulled.
I did check the tail lights originally and get 0v at all pins. I was trying to chase to see if I could find any shorts but I can not find any. Didn’t know if there were any obvious junctions/points of failure I should be looking foreword
