LR3 Timing Set Replacement
Old 04-02-2022 | 06:47 AM
P-Bod's Avatar
Do the same on the right.
Remove the flex plate and cam locks. Motor is timed.
  #42
Old 04-02-2022 | 06:56 AM
P-Bod's Avatar
I hand cranked the motor several revolutions and all feels good. While rolling, you can see certain points where the chains are tighter and looser I presume from the position of each cam. This is where oil pressure in the tensioners really does its job to keep everything tight.
tracyc (04-02-2022)
  #43
Old 04-02-2022 | 09:47 AM
P-Bod's Avatar
Front cover and harmonic balancer torqued. Crank spec is 280 ft. lbs. My torque wrench goes to 250 so I hit that plus a smidge.
  #44
Old 04-02-2022 | 12:04 PM
DakotaTravler's Avatar
Would be really easy to get to that oil filter housing adapter gasket. They can leak and I believe the gasket seals both oil and coolant passages. The gasket is basically two o-rings moulded as one. LVF500010 I believe is the part number.
  #45
Old 04-02-2022 | 12:22 PM
P-Bod's Avatar
Good call. Local dealer has one in stock. I’m going to go grab it. Thanks!
  #46
Old 04-02-2022 | 01:01 PM
P-Bod's Avatar
  #47
Old 04-02-2022 | 02:06 PM
houm_wa's Avatar
Default This is an awesome thread!!
...keep it up!
  #48
Old 04-02-2022 | 02:15 PM
P-Bod's Avatar
All better.
  #49
Old 04-02-2022 | 02:53 PM
P-Bod's Avatar
  #50
Old 04-02-2022 | 03:02 PM
P-Bod's Avatar
I forgot to mention earlier, the new idler pulley has rails on both edges. There’s a TSB, LTB00067 4/7/2009, that I didn’t understand until I installed the pulley and it rubbed the bracket. I had to shave a little bit with a Dremel for clearance.
Quick Reply: LR3 Timing Set Replacement
