LR3 Timing Set Replacement
Old 04-02-2022 | 03:58 PM
P-Bod's Avatar
Things just went south, literally. As I was relocating the wiring harness for the A/C compressor bracket I heard a light snap then some clankity-clank noises. By shear luck, I found the cracked plastic mounting clip with my borescope. There’s no way in h I can extract it. I’m trying to talk myself out of pulling the front cover, but I don’t think I can.
  #52
Old 04-02-2022 | 04:18 PM
P-Bod's Avatar
I can’t believe it… I actually got it!!!
The following 3 users liked this post by P-Bod:
Dai20bt (04-05-2022), houm_wa (04-02-2022), SeattleDriver (04-02-2022)
  #53
Old 04-02-2022 | 06:46 PM
P-Bod's Avatar
After that scare, I buttoned up the LH cover.
  #54
Old 04-02-2022 | 07:36 PM
DakotaTravler's Avatar
Did you get new seals for the valve cover / VVT solenoid interface? They leak oil. Highly recommend OEM only on those. If not, no worries. They slip over the top of the solenoid easy enough, no disassembly required.
  #55
Old 04-02-2022 | 09:40 PM
P-Bod's Avatar
I did put new solenoid seals in. Not OEM, but Italian made. Also new gasket and spark plug seals. The parts kit I bought also came with valve cover bolt seals, but I chose not to use them. I don’t think they were silicone so I reused the factory bolt seals.
Yes, it does look like the solenoid seals are easy to pop out and replace. Might be the only easy thing!
I feel for those who have replaced the power steering pump and A/C compressor. A lot of trick socketry to get these things back on!
  #56
Old 04-02-2022 | 10:29 PM
houm_wa's Avatar
Default Totally easy!
Even I could accomplish that one, and did!
  #57
Old 04-03-2022 | 09:39 AM
P-Bod's Avatar
Accessory belt on, the second time. Had to re-route due to feeble memory and not having the exact right pictures.
Fan belt on.
RH valve cover buttoned up.
  #58
Old 04-03-2022 | 11:06 AM
Ive always been amazed by how little contact there is on the belts with the ac compressor and ps pump. Seems to be about 25% or so. Most I have worked on are at least 50%. Awesome work and really appreciate the documentation efforts. One of the best threads I have seen in a long time.
  #59
Old 04-03-2022 | 11:56 AM
P-Bod's Avatar
Coolant crossover, EGR plenum (?), and EGR ready. URO crossover. Wish me luck on that.
  #60
Old 04-03-2022 | 12:31 PM
P-Bod's Avatar
Freshly cleaned throttle body and new connector latch.
houm_wa (04-03-2022)
Quick Reply: LR3 Timing Set Replacement
