LR3 Upper Steering Shaft/Column u-Joint replaceable?
Old May 26, 2023 | 08:07 PM
DakotaTravler's Avatar
Default LR3 Upper Steering Shaft/Column u-Joint replaceable?
Steering saga... So my lower bound up again after 100k miles. Put a new one in. Then on a technical trail with lots of movement between body and frame I was hearing a loud metal on metal sharp knock and occasional squeaks from under the main steering column in the cabin. I found my intermediate shaft was bent or damaged a bit. Found out by rotating steering wheel and seeing where the shaft comes out of the firewall was going in a circular motion, not spinning on its axis. So I have a new OEM intermediate shaft to put in but it does not come with the upper u-joint. I suspect the u-joint is the source of some play/wondering and the noises.
Below are two pics. One is the main column and these can be had cheap, so no worries if I have to just do the whole thing. But the other pic is of one more broken down. And you can see a section of shaft with the joint is missing. Wondering if just that is swappable? Or just the joint?
Marcopolo
Jul 26, 2022 05:36 PM
gypsy
Mar 23, 2020 03:57 PM
Airborne2016
Nov 18, 2019 06:12 PM
Dave03S
Nov 5, 2019 08:33 PM
dtmbinb
Aug 30, 2018 05:38 PM
