LR3 valve block oring size
Old Jan 31, 2022 | 08:18 PM
siennah22's Avatar
4th Gear
Default LR3 valve block oring size
Replaced the o'rings on the valve blocks and realized I have a small air leak due to some of the o'rings being the wrong dimensions.
Anyone know the correct dimensions, or where I can buy the CORRECT oring kit?
Old Feb 1, 2022 | 10:24 AM
DakotaTravler's Avatar
Every kit I have seen has the correct sizes. Are you sure you installed the correct ones? They kits are for all three blocks after all.
Old Feb 4, 2022 | 09:58 AM
siennah22's Avatar
4th Gear
100% positive I installed them correctly. And I've seen alot of people having the same problem I'm having.
Old Feb 4, 2022 | 11:32 AM
douglastic's Avatar
Were your old o-rings visibly damaged?
I had success just R/R original o-rings after an open/cleaning out the dust.
Holds air like new.
Old Feb 4, 2022 | 11:41 AM
siennah22's Avatar
4th Gear
Holds air like new.
Unfortunately I do not have the old o'rings, left them out at a family members shop and they got thrown out.
That's why I'm asking if anyone knows the size of the original ones.
Old Feb 4, 2022 | 02:12 PM
Are you sure its not descent contamination on the new o-rings? When servicing valve blocks is best to replace the dryer desiccant as that is often the cause of leaks. Once that is done, wait a couple weeks for the small desiccant powder to get out od the system before servicing valve blocks. Of course double check your line connections, cant tell you the number of times people have a leak and it ends up being the connections after servicing the block.
Old Feb 4, 2022 | 02:18 PM
siennah22's Avatar
4th Gear
Already did that. And made sure the line connections were good. And when I did the soapy water test after putting in the new o'rings, the bubbles were coming from the wiring harness.
WaltNYC
Range Rover P38 (2nd Gen)
Dec 2, 2021 11:43 AM
scoutrover13
Dec 14, 2020 02:23 PM
josher-mi
Jan 19, 2019 01:54 PM
packkratt
Dec 10, 2016 11:14 AM
workinghard1713
Nov 18, 2012 05:34 PM
