LR3 won't shift into Drive
Old May 31, 2011 | 04:41 PM
sjewell's Avatar
3rd Gear
Default LR3 won't shift into Drive
when trying to shift into drive, lever sort of springs back toward N. "D" never shows up on dash. When I put in manual mode car still will not move, when I give it gas it sounds like it is in neutral. Reverse works fine.
Any suggestions?
Old May 31, 2011 | 06:50 PM
unseenone's Avatar
Default answer is here
https://landroverforums.com/forum/lr...00miles-40903/
Old Sep 12, 2019 | 10:16 AM
Sean Parker's Avatar
Default DID you get an answer
Any suggestions?
Did you ever figure this out!
Old Sep 12, 2019 | 11:55 AM
Shift linkage is probably bound up. Sometimes you can pull the transmission cover and spray the linkage as a temporary fix.
Andy McDonnell
Jun 12, 2023 12:38 PM
gman21
Feb 18, 2013 02:40 PM
RabbiCP
Jun 4, 2011 12:39 PM
Joentuff
Mar 14, 2011 10:02 PM
challishodge
Aug 7, 2010 11:06 AM
