MOST
Old 12-21-2004, 04:59 AM
tropnevad's Avatar
Default MOST
Does anyone know where you can find detailed information, white papers, etc. regarding the MOST fiber optic connections?
Has anyone experimented with the MOST system, in an LR3 or RR?
I would like to tap into the network and input video to the nav screen, and audio to the head unit.
I believe that the head unit is sourced from Alpine and equipped with upgradeable flash memory. Do you know if there will be an XM or Sirius upgrade? I do not want to give up my satellite radio.
Old 12-24-2004, 04:33 AM
Lighting90's Avatar
Default RE: MOST
Pass, you could try asking the same question on other Land Rover forums..
Old 02-01-2005, 06:56 PM
roversales's Avatar
Default RE: MOST
My 1st post.
Sorry, I don't know where to find detailed info about the MOST system. However, the Head unit is not an Alpine unit. The NAV system in the LR3 and '05 Range Rover is a Denso unit, very similar to the ones in the Jags & Lexus's.
Best of luck to you, but from what I've heard, the new Fibre systems are impossible to splice into unless you can create software to integrate. Good luck
Old 02-22-2005, 04:12 PM
jzk's Avatar
jzk
jzk is offline
7th Gear
Default RE: MOST
If you find anything, please post. It would be cool to download waypoints and routes to and from the nav system.
hilltoppersx
ROAMING WITH FRIENDS
12-07-2010 05:48 PM
Landzu
Off Topic
02-17-2006 03:05 AM
Patrick
Off Topic
12-08-2005 03:01 PM
Nux
10-26-2005 03:43 AM
brianwi11iams
02-15-2005 01:54 AM
Quick Reply: MOST
