my 05 lr3
Old May 8, 2016 | 09:58 PM
  #91
bbyer's Avatar
Default 3.5" left and 4.5" down
.... so drill about 3.5" left and 4.5" down then.
That is good to know as I guess one would have the same problem when removing the upper hatch.
Old May 9, 2016 | 09:50 PM
  #92
TOM R's Avatar
3.5x 4 7/8"? Guess eyeball it from the pics just drill slooooooow
Old Jun 11, 2016 | 02:06 PM
  #93
TOM R's Avatar
New sneakers , 100 each wholesale
Only drove a few miles so far but seem nice, took a lot of weights though ( but that might be my buddies balancer)
Old Jun 11, 2016 | 02:08 PM
  #94
TOM R's Avatar
Old Jun 11, 2016 | 04:47 PM
  #95
TOM R's Avatar
Btw, the GPS repair is confirmed as a success , took a trip to del. Yesterday nav worked perfect
Old Nov 2, 2017 | 03:26 PM
  #96
TOM R's Avatar
Did spark plugs today replaced with same as stock from amazon
She has 83600 miles now, the coolant tube in front leaks so thats next, plus belts and trans service ,parts sitting here just trying to find the time
All loo
ked like this
Old Nov 2, 2017 | 07:40 PM
  #97
Hoping to get to my plugs this weekend, along with some other services.
Old Nov 2, 2017 | 10:28 PM
  #98
TOM R's Avatar
They were easy probly an hour just going normal pace, i did put a dab of never sieze on threads since the old ones looked like there was some corrosion
I used a universal spark pkug socket and 6" wobble extension , a few coils were tight clearance but they came out
Seemed best to unhook all coil plugs front to rear then replace the spark plugs rear to front
Pass side had to pull the maf and airbox lid and there is a breather thing on the valve cover, also helped to take the heater core hoses out of the front and rear mounts and put them onto the engine so the coils can clear and you can get the rachet in
The hardest is drivers rear but it will come out if you push on that heat shiel and wiggle the coil
I thought. About dielectric grease on the connections and the tops of the spark plugs but i did not have some handy
Old Nov 2, 2017 | 10:33 PM
  #99
houm_wa's Avatar
Good time to do the BG fuel cleaner....right before plugs and oil.
Old Sep 23, 2018 | 12:18 PM
  #100
Yasser Iskandar's Avatar
3rd Gear
Question Lr3 2008
Originalmente publicado por Yasser Iskandar
Meu nome é Yasser, sou do Brasil. Eu tenho um LR3 2008 ea bateria foi completamente descarregada ... oh o burro aki colocar o carregador de bateria para carregar, mas eu não vi que o carregador de bateria foi 110W e eu liguei no 220W que foi cerca de 10 seg.
Quando percebi que peguei a voltagem e coloquei apenas a bateria pra carregar ... carreguei os cabos e quando comecei encontrei a letra E no meu painel eo carro não solta a alavanca de câmbio e não liga. .. Eu tentei 3 queimadores fusíveis e eu mudei eles e mesmo assim não era a letra E do painel !!!!
Por favor, você poderia me ajudar com sua orientação e conhecimento.
