A new one for me....
Can't replicate it but I can tell you that if you run a live values session with the tool and don't clear all the faults afterwards then you get the Christmas tree effect because some ECUs don't transmit values during a live session and these re interpreted as faults buy the others and it cascades
My problem started when two light bulbs blew and created a DTC. I changed the bulbs but I am not sure if I cleared the DTCs. Some time later I had the HDC light and EBA and ABS so I was told to change the battery and reset the BMS. During this time I sometimes had the IIDTool in and sometimes cleared and sometimes did live readings in a very undisciplined manner. A few days ago after many lights shows I noticed that the live reading can cause ECUs to not transmit and this leads others to think there are errors and it cascades. I had a light show, cleared the errors and the lights went out - all of them. So I am due to do some more tests today but I start to think the very presence of the tool many screw up the car sometimes and I am not sure if the clearing clearis all the errors including the ones leading to no lights (there is a choice of confirmed, pending etc) I don't know the structure of the software or how it works on either the car or the tool but I will dig into it and see if I can come to some conclusions. I am currently working on the assumption that the tool is a cause as well as a solution. However, clear all DTCs after a live session and don't run with the toll plugged in
my experience may help. I recently did front control arm bushings and left the front of the lr3 in the air for about a week while I waited for parts etc. I did NOT disconnect the battery or pull the air sus fuse.
when i was done, it didn't want to raise back up (rear bags deflated to bumpstops while it was up in the front), and I had a myriad of faults. I jacked up the rear a little and the truck started filling the bags.
After I got the suspension at normal height, I still had faults so I disconnected the battery over night. Reconnected the battery the next day, and got faults quickly stating loss communication and air pump filling slowly.
So I cleared the faults with my I land tool and drove to get the alignment. Once that was done, I didn't get faults for a long while. I do have a front proportioning valve issue so i do get a bags filling slowly fault from time to time
Moral is I think that sometimes after working on the truck, If I don't disconnect the battery before lifting, the air suspension freaks out and has to be reset
COSitsWORTHit - do you have sensor rods installed? If so, that is why that happened. The system has no programing protocols that would generate a code even is slammed, it would just air up. But as we know, rods pushing the sensors out of range, past their limits. So the only way to get lift is to jack it up so the sensors read again and the system again knows where stuff is.
The_OGCJR (02-05-2022)
ABS, HDC, EBA, gearbox fault, check engine, EPB, fuel low, no special programs, speedo not working fuel gauge not working, system error, battery fault, limp mode etc etc
Cleared the faults but IID Tool would not always connect or clear faults (update failed). After a few goes, everything cleared and all is back to normal - until the next time no doubt
I am at my wits end
I am at my wits end
