Nothing is simple or easy
Old Oct 13, 2014 | 09:57 AM
Rufflyer's Avatar
Default Nothing is simple or easy
OK, so after reading all of the compressor rebuild threads (thank you so much to all of you who have pioneered this for the rest of us and made the info available) I collected the rebuild kit, then realized it would be less than intelligent to remove the compressor without the $.026 brackets so back to the web to order three new brackets. Well as it happens the three little parts with shipping was over $11.65. I was off work today so last Saturday, I make a trip to the local LR dealer, spend the gas to drive 38 miles one way, then paid $1.70 a piece. Well I figured that was the cost for wanting to do this on Monday and it was about the same cost but I now had them in my hand!
Put the ramps in front of the left wheels, and for some reason thought low range seemed the right thing to do. I also most drove over the ramps and had to back up to get them centered. Placed my trusty wheel chocks in place and removed the compressor cover.
I immediately saw this......
Well another trip to the inter web and this is now a project for next weekend. B-)
I will post the outcome after it is installed.
Old Oct 13, 2014 | 02:08 PM
houm_wa's Avatar
Ouch! Tactical 4x4 sells a bracket for the Compressor. It's meant to relocate the AMK but I'd think it'd be fine for the Hitachi as well.
Old Oct 13, 2014 | 07:12 PM
bbyer's Avatar
I complement you trying to be prepared. Whenever I contemplate work on my 3, I plan weeks in advance and set aside a number of days for the most minor task. It just seems to be needed.
The broken compressor bracket is not exactly unusual but certainly is a nuisance. I have one in my spares collection.
When going under my 3, I like to put frame jacks under as I never know when the air system is going to let go - well I figure it would be when I was under it but fiddling with the air system pretty much ups the odds.
We will be all interested in the outcome of your latest adventure and we sympathize.
Old Oct 13, 2014 | 07:51 PM
Rufflyer's Avatar
It just keeps getting better. For some reason, I pulled fuse 3 and 26 before I drove up on the ramps. Since this project was on hold I decided to replace the coolant level sensor (at least one thing went right). And only one...... Just took it to the store and the normal ride height light came on, so now I start down a completely different rabbit hole.
Old Oct 13, 2014 | 08:06 PM
TOM R's Avatar
How do you tell the amk from hitachi
Old Oct 13, 2014 | 08:45 PM
houm_wa's Avatar
Well for starters the AMK is mounted to a really thick aluminum bracket on its bottom side....
Old Oct 13, 2014 | 08:46 PM
bbyer's Avatar
Default lower half of case more square
From the outside, the bottom half of the AMK black plastic sound surround case is a bit more square than with the Hitachi. Probably if you park your 3 beside a new 4, you would be able to see the difference - but it is not much.
Old Oct 13, 2014 | 09:05 PM
TOM R's Avatar
Is the pic above the Hitachi?
Old Oct 13, 2014 | 10:01 PM
bbyer's Avatar
Default yes, Hitachi
Yes, the jpg in the first post is the Hitachi compressor.
The link below shows a bit of the Hitachi's internals and also what a new compressor bracket looks like.
DISCO3.CO.UK Photo Gallery - Broken Air Compressor RQG500060
This is a link to a 9 page thread on the new AMK.
New EAS Compessor Option - Australian Land Rover Owners
The attached jpg's show the lower half of the AMK compressor case; also an exploded view of the Hitachi compressor.
Attached Thumbnails Nothing is simple or easy-air-compressor-exploded-view-showing-covers-bracket.jpg   Nothing is simple or easy-amk-compressor-cover-bottom-half-mounted.jpg
Old Oct 24, 2014 | 08:51 PM
Rufflyer's Avatar
Default Problem solved
After replacing the bracket, putting the compressor rebuild kit in, the normal ride height warning remained.
The compressor would run about 5 seconds then shutoff abruptly.
Then.......... Hdc, amber brake light, movable headlight , dynamic suspension control lights are all lite up.
I gave up and took it to the local Indy shop.
I took the expensive option and replaced the compressor with a new AMK compressor upgrade.
Seems the electric motor was burned out and would only run a few seconds before it would overheat and shut off.
Well I am forcing myself to be happy with the new style compressor. B-)
