Offroad lights
Regarding engine, I assume that you are referring to the 5.0, litre, not the new small econ V6 unit that Land Rover refuses to admit to.
You may note that on the rear of the new LR4's, (at least up here), there is no reference to an engine any longer, (nor in the dealer showroom either).
In the UK etc, where they have the various diesels, it is not an issue but here .... - well there is talk of bringing diesel Stateside but until then ....
I also like the door panels but still prefer our dash layout and separate displays for Nav and Radio - and the round analogue clock is nice as well.
I am not so keen about the missing oil dipstick either - bad enough not to have a transmission dip stick, but no engine oil one either!
I guess I like my 3.
In order to wire that up, you also need to tell the vehicle it is installed by programming the computer. It's a good setup. Do you need the installation instructions for the factory kit, maybe that would be a good place to start. If you need the factory installation manual, drop me a PM w/e-mail and I'll send it to you.
Could you help me with the installation instructions please? I have been trying to find them...
I assume you read my post #4 on page 1 and reviewed the link within.
Here is another link to the hookup that refers back to my post #4 link.
How to add the factory Driving Light switch to your aftermarket driving/fog lights
The attached pdf below is the factory picture instructions.
You can download it and then print it out.
Thanks
Do we think it would be a pretty straightforward process to swap out these older lights with newer LEDs? I don’t need to add anymore lights, but would like to make these a little brighter for night time driving on country roads.
I presume then you have two factory auxiliary lights kind of located on top of the bumper per below and now two of your own installed on the roof rack.
By EU law and maybe North America law as well, auxiliary road headlights can only be illuminated with the factory high beams also on. In other words, you are not supposed to drive on a legal road with only the aux lights illuminated.
Also all aux lights are supposed to go off when low or dipped beam is selected.
A bigger question is how are you going to run some power wires up to the rack lights? The answer is not an easy one.
I do not know how many amps the factory setup is designed for, hence tapping that circuit at the output might not be a good idea.
Also you will still need a separate switch; probably the best bet is to install a second factory switch, and attach to some of the first factory switch conductors but do it such that both switches operate independent of each other - it should be doable; the hardest part will be to find a location for the second switch.
I've reached out before but did not get an answer, I was just trying to find out what type of spot light that you had in the photo shown in the post, i'm trying to get some lights with a grid at the front and like the look of these.
Thanks a lot,
Regards,
Erick
