Okay Braintrust, I need an assist!
Old Aug 26, 2025 | 08:45 PM
houm_wa's Avatar
Default Welll….
I can shake the hell out of the prop shaft, so I’m thinking it’s the Carrier Bearing. Replace the whole thing or can I do just the bearing? Maybe after all the banging around, the whole shaft would be wise….
…anyone have a brand recommendation?
edit: damn, the bearing is wayyy cheaper than the shaft. Any recommendations on the brand on the bearing? 😀
Old Aug 26, 2025 | 09:40 PM
Gnomadf's Avatar
that bearing is tricky to replace. I've tried it twice with a 100% failure rate. I gave up and bought a cheap and cheerful Amazon prop shaft which works fine.
Old Aug 26, 2025 | 10:36 PM
DakotaTravler's Avatar
National is often a good bearing brand.
Old Aug 27, 2025 | 09:52 AM
houm_wa's Avatar
National is pretty hard to source....plenty of "Mako" bearings. Anyone try these?
Old Aug 28, 2025 | 08:01 PM
Rock Auto has a ton of National bearings for the LR3.
Old Aug 28, 2025 | 10:23 PM
houm_wa's Avatar
Default I just looked…
…and didn’t see any on Rock Auto’s website. I’ll have to look again when I’m on my actual computer versus my phone. Thanks for the tip!
Old Aug 29, 2025 | 10:30 PM
loanrangie's Avatar
Bearing is fiddly to change, my shaft only lasted about 6 months before the CV joint near the bearing got notchy. If the CV's and rear uni feel good its worth trying just the bearing.
Old Sep 1, 2025 | 09:21 PM
Gnomadf's Avatar
Also, if the rear uni feels notchy you can't really get the old one out. I tried to press it out with my 12 ton press and couldn't get it out of the carrier, and then even if you did there are no snap rings to keep it in place, looks swaged in. So, don't bother.
Old Sep 8, 2025 | 05:37 PM
houm_wa's Avatar
Well....a little late for that; part is on the way. Worth the gamble. If they can't press it out, I'll just get a new shaft. I have other vehicles so the time waiting for it isn't much of an issue.
Viking1
May 3, 2024 01:45 PM
wittingsun
Nov 1, 2015 06:03 AM
MMWnLMD
Oct 7, 2012 08:09 PM
LRadventure
Sep 16, 2010 07:59 PM
