Old question...hoping for updated results?
Hi all,
I've seen old threads with mixed reviews on whether or not the oil can be sucked out of the LR3's dipstick hole by a Mityvac or equivalent extraction system....has anyone successfully done this? By successful I mean all 8 quarts or close to it....Thanks in advance.
-Houm
-Houm
Thats an odd question....
Is this to make oil changes a little less of a hassle? If so I often thought of doing a couple things. First would be to make a removable area on skid plate, an access hatch. Or just even have an opening big enough for one to get a hand in. Then get one of those locking drain valves, for the Rover the 90 degree one is perfect. Simply attach hose then open the valve. No drain plug to remove. So you just need access to attach a hose and open the valve.
drain valve:
drain valve:
