Parking Brake Light
Parking Brake Light
I’m hoping someone’s knowledge here will provide me with an easy solution to eliminating an annoying “parking brake fault” alarm light on my dash.
I’ve retrofitted a custom, good ole fashion, manual parking brake lever. So there’s no need for that EPB Module. But that amber light! Omg how do I eliminate it? Any ideas?
thank you and have a grateful memorial holiday to all.
I should have probably added that before retrofitting the manual lever, the epb was accidentally applied with no shoes attached…oops.
the module was removed and the lead-screw mechanism was unwound so that the 2 metal ends reclipped together. After replugging the electrical connector to the module (no stainless cables attached) the dash still shows an alarm.
I’m really at a loss.
i just tried reattaching the epb module and while my son lifted the brake switch I was back there applying pressure to the cog as it performed its “set-up” operation (or whatever it is it does when you first plug it in.
perhaps I could do some witchcraft to the epb module wiring harness so the computer thinks all is swell?
johnsonmc2000 (06-12-2024)
