Part number for coolant fitting?
Old Jan 22, 2016 | 03:51 PM
tnk's Avatar
tnk
Default Part number for coolant fitting?
Hey all,
Does anyone have the part number for this plastic fitting (with metal cap) that is part of the coolant outlet to the cylinder head? I found the hose and fitting combo, but it's 90 bucks and my hose is in decent shape.
Also, what is the purpose of this fitting? Mine broke so I have replaced it temporarily with a brass fitting.
Thanks!
Here's the broken one..
Old Jan 22, 2016 | 04:15 PM
Niver39's Avatar
LR027661
Land Rover LR3 Range Rover Sport 4 4L V8 Coolant Hose Air Bleed Valve Genuine | eBay
Old Jan 22, 2016 | 04:30 PM
tnk's Avatar
tnk
High point bleed valve. Makes sense. Thanks for the part number!
Old Jan 23, 2016 | 10:48 AM
schwaggy's Avatar
Spend more money and get a part that will never fail again:
Upgrade for silly plastic T fitting in hose for Land Rover LR3
Old Jan 23, 2016 | 11:20 AM
thorgal's Avatar
60 bucks for a little brass Tee ?!!
Old Jan 23, 2016 | 11:43 AM
Volkov's Avatar
That price is obscene
Old Jan 23, 2016 | 01:21 PM
Niver39's Avatar
Or you could do the trail fix and use a bic pen!
Old Jan 23, 2016 | 03:17 PM
thorgal's Avatar
I actually replaced mine along with all the rubber hoses at 116 000 miles as preventive measure and also carry extra T bleeder as a spare, in case of trail break up.What bathers me though is the general greed for a parts , that should cost 1/5 of that price. It seams that every American company wants to make a million bucks overnight , they don't look for a long term relationship with customer, after all cars nowadays are not meant to last long, but scrap as quickly as possible for razors and such.
Old Jan 24, 2016 | 01:17 AM
DavC's Avatar
It should be noted that a few people reported the brass T fittings can leak. OEM one does not but is fragile, so I carry a spare too. Unless you do A LOT of coolant work in that area the fitting should be fine (just use two wrenches to unscrew slowly). The fitting that came with the truck lasted 8 years before I cracked it trying to replace it with a brand new one. One end usually snaps off when you try and pull one of the hoses off. A dealer should be able to get you a new one by itself for a few bucks (no more than $20 IIRC).
EDIT: to top question, its a cap that allows you to bleed air from the system since it is located at the highest point in the coolant loop. IMO you don't ever need to use it for that, the system can be 'burped' without touching it.
Old Jan 25, 2016 | 05:15 PM
tnk's Avatar
tnk
Thanks man, I've got a brass splice in there right now with no vent fitting at all. I didn't use anything other than the expansion tank screw when I topped up after the hose blew off when the fitting broke. I haven't decided if I'm going to put a replacement bleeder in there yet, but I have to make a trip over to the dealer to pick up some T-case fluid anyway, I might see if they have any.
