Part Numbers Needed....
Old Apr 29, 2025 | 11:46 PM
houm_wa's Avatar
Default Part Numbers Needed....
Hey crew. I just picked up an '07 and the little flappy thing that bridges the gap between the boot and the lower tailgate is missing some hardware. A few of the springs are compromised and some of the plastic? fasteners that go through the horizontal holes are missing.
Does anyone know those PNs and where I might source them?
Thanks in advance.
-Houm
Old Apr 30, 2025 | 08:02 AM
gmtech's Avatar
junkyard .. find an LR3 on marketplace near you that someone is parting out..
Old Apr 30, 2025 | 09:34 AM
kajtzu's Avatar
Probably EYC500121 or the older EYC500120? Lrcat is your friend https://lrcat.com/#!/12128/46398/46653/3678/46841
edit: actually I think you meant the other thing, what they call the scuff plate https://lrcat.com/#!/12128/46398/46653/3669/46788. It happens that the clips are the same.
not sure if the springs (hinges?) are available separately…. Lrcat implies they aren’t but it is not always correct.
Old Apr 30, 2025 | 03:58 PM
houm_wa's Avatar
Thank you for the link, that's awesome!
I don't think either of those links reflect the piece I'm thinking of, but I'll look through LRCAT to see if I can find it. If you drop your lower tailgate, there is a little panel that flops down and rests between the tailgate and the load floor. That is the piece I'm talking about. You probably understood me the first time, and maybe I'm looking at the lrcat diagram wrong...just looks a bit different.
Old Apr 30, 2025 | 04:24 PM
kajtzu's Avatar
I think the part is EAN500101PVJ (anthracite so kind of black-ish) or EBZ500011. The latter doesn’t show up on lrcat but if you google it and eBay or image search you get the “bridging part” between the trunk and the lower tailgate which you described.
Old Apr 30, 2025 | 04:37 PM
kajtzu's Avatar
It’s this part that’s outlined in green that you want meant, right? I’m pretty sure I got the part right through lrcat. It’s the second link I pasted. The first link had the inner trim of the tailgate where the cables mount.
Old Apr 30, 2025 | 05:18 PM
houm_wa's Avatar
That's the one! Specifically the hardware but if the part is sold as one assembly including springs and fasteners, then so be it. Thank you very much!
Old May 9, 2025 | 03:31 PM
houm_wa's Avatar
Ordered, delivered, and INSTALLED!
Thanks again....
Old May 10, 2025 | 05:36 AM
kajtzu's Avatar
You’re welcome. This forum has helped me immensely over the years. 👍
Old May 11, 2025 | 09:02 PM
houm_wa's Avatar
I suppose I could use the sa
me resource to find the cover to the seat belt and the 3rd row seat handle thing, eh?
