Permanent Suspension code on LR3
Old 02-11-2021, 07:08 AM
colinoickle@hotmail.com's Avatar
Default Permanent Suspension code on LR3
Hello All, First time posting, and new LR3 owner.
Does anyone have experience with the C1A28-64 (wrong number of LED's illuminated) suspension code? I can clear the code but it comes back immediately when I turn on the ignition key.
For some background, I recently purchased the LR3 from the local LR Dealer "as-is", needed ball joints and sway bar links, suspension light on, will not raise or lower but will maintain normal drive height.
The compressor would cycle each time the vehicle was started but would turn off and trigger the C1A20-64 suspension code, which I believe was triggered by a crack in the air drier cover, once I fixed the cover the code went away.
The compressor then ran for a couple of minutes before shutting off, which I assume would be normal with a completely deflated suspension, however, the suspension did not lift (currently on the bump stops after ball joints replacement)
So I'm left with the permanent code as mentioned above, and a rover that is sitting on bump stops.
Looking for guidance if anyone can help, thanks!
Old 02-11-2021, 08:35 AM
Received 1,589 Likes on 1,305 Posts
For the LR3 isn't that code related to the DSC?
Old 02-11-2021, 10:18 AM
[QUOTE=ArmyRover;761002]For the LR3 isn't that code related to the DSC
I’m not to sure. The vehicle is new to me so I’m not sure what lights are supposed to be illuminated in the first place. There are no led’s illuminated on the height control lever on the centre console, and the lever itself is not functioning at the moment so I’m leaning towards that being the issue.
Old 02-11-2021, 01:10 PM
houm_wa's Avatar
Maybe start with a hard reset....?
Old 02-11-2021, 09:56 PM
loanrangie's Avatar
i found this on the code , page 20 - https://docplayer.net/150647052-Vehi...ing-modes.html
rong Number of
LEDs Illuminated
Wrong number of LEDs
illuminated on switch
pack
Air suspension control
module supply
(BATTERY) fuse in
battery junction box
(BJB) failed
Switch pack harness
wiring short circuit to
ground, short circuit to
power or high
resistance
LED circuit short circuit
to power
One or more LEDs
short circuit to each
Check/renew fuse as necessary.
Refer to the electrical guides. Refer to
the electrical guides and check the
switch pack and LED wiring circuits.
Renew/repair as necessary. Refer to
the warranty policy and procedures
information if a module is suspec
Sdover
11-27-2020 08:41 AM
Kevin Kilo Jones
02-17-2019 12:02 PM
BigDaddy12
02-05-2017 06:02 AM
gmad
10-02-2015 01:33 PM
NhudeST
01-18-2011 06:22 PM
Quick Reply: Permanent Suspension code on LR3
