The Plight of the lean codes
Old Oct 1, 2019 | 06:49 AM
mirepoixmatt's Avatar
Originally Posted by LR Techniker
Do you have lean codes for both banks or just one bank? An exhaust leak on one bank, will not effect the fuel trims on the other bank. So if both banks are lean, then you either have exhaust leaks on both sides, or you have a global issue (effects both banks, i.e. MAF sensor, intake leak, low fuel pressure, etc...).
Both banks are lean. Based on the images I posted - do my fuel trims look abnormal ?
I like your comments. It at least centers me. It doesn’t seem plausible that I have leaks on both sides (unless it’s exhaust manifold ?)
Old Oct 1, 2019 | 11:08 AM
AtlantaViking's Avatar
When I bumped into the lean code issue, while it was only one bank, i went ahead and checked exhaust manifold bolts on both side and they were both on the loose side - so don't necessarily dismiss them. I doubt it's your issue but it worth a check. Also, I didn't see where you posted the actual lean codes, are they pre or post cat?
Old Oct 11, 2019 | 12:09 PM
sickws6's Avatar
Any updates? I have same issue!
Old Oct 12, 2019 | 04:21 AM
Globetrotter448's Avatar
Some temporary fix that clamp is. The o2 sensors tell the ecu when to lean the fuel, so as you have 'lean' codes I would not think it is an exhaust or o2 problem but more an air input or lack of it, problem. You have checked the air filter and throttle body??
Old Oct 12, 2019 | 11:12 AM
LR Techniker's Avatar
Exhaust leaks will certainly cause a lean code. Its called an Oxygen Sensor because it detects Oxygen. Exhaust goes through the manifold in "pulses", which is why exhaust leaks make a "puff puff" sound. When its not expelling exhaust, its drawing outside air in. This air drawn in, contains 21% Oxygen and the sensor doesn't know there is a leak, it just assumes its from the engine and tells the ECU that the fuel mixture is too lean.
aarcaris94
Oct 1, 2019 07:29 AM
pgoodrich
Feb 8, 2016 08:58 PM
04SSHD
Apr 11, 2012 06:20 PM
jkid
Nov 29, 2008 04:48 PM
Trooper
Jun 26, 2008 08:18 PM
