Proper Spec Suspension Lift Kit Proud Rhino Lift Rods
Old Sep 4, 2017 | 11:30 PM
cmshoot's Avatar
Default Proper Spec Suspension Lift Kit Proud Rhino Lift Rods
Good or bad idea? If bad, what would be the issue(s)? Link below.
Amazon Amazon
Semper Fi!
Old Sep 5, 2017 | 06:45 AM
Work great I have them on 1 of my trucks. No issues with them at all. Rides just the same only taller.
Old Sep 5, 2017 | 10:11 AM
OverRover's Avatar
Yes they are a good idea, and no issues.
And "Proper Spec" is Lucky8, so you'll have no worries with the vendor > https://www.lucky8llc.com/collection...+ac2-lift-rods
Old Sep 7, 2017 | 10:43 PM
cmshoot's Avatar
Thanks, y'all.
Old Nov 22, 2017 | 08:50 AM
cmshoot's Avatar
If I install these, then my LR3 will stay at that same, raised height all the time? I won’t be able to adjust it down any?
Old Nov 22, 2017 | 11:52 AM
It will still raise and lower everything will be 2.5" higher.
Old Nov 22, 2017 | 11:57 AM
cmshoot's Avatar
Thank you
Old Nov 22, 2017 | 12:04 PM
houm_wa's Avatar
You probably can but just not in the same range as without them. Do you have an IIDTool? If you don't, you should. If you do, then you ought to know that you can create and save a taller height setting and use it when you want. No hardware.
Old Nov 23, 2017 | 06:17 PM
cmshoot's Avatar
I do not have one. Thanks.
Old Nov 23, 2017 | 06:58 PM
Check their black friday ad Lucky8 has a huge sale going on the lift rods right now
