Question and Help for Quick Release hitch
Old Apr 24, 2017 | 08:02 PM
ClearwaterScott's Avatar
4th Gear
@Burgus -- I am having exactly the same issue. Would love to hear how you ultimately resolved the issue.
Cheers!
Old Apr 25, 2017 | 06:58 AM
Bergus's Avatar
3rd Gear
@clearwaterscott. While I would like to say that I developed an ingenious solution to fix the problem, I ultimately was able to push in and turn the lock so that the pin retracted when I slid the hitch into the receiver. However, I will say that I tried this same process several times prior to my post without success and event resorted to trying to take the hitch apart in an effort to investigate if internal gear teeth were stripped. In the end, it was trial and error until the pin retracted. I suspect that the lock was not rotating far enough to release the pin. Note: I haven't taken the receiver off since so not sure if this will be repeatable, but I'LL post back if it does.
Old Apr 25, 2017 | 10:16 PM
4th Gear
@Bergus -- Thanks for the reply. I really was hoping this was just another example of my foolishness or some obvious fix. I have turned, pulled, pushed, pounded, cursed and kicked the thing. Nothing seems to budge the pin. I may resort to disassembling the unit but frankly don't want the hassle every time i use the unit.
Old Apr 25, 2017 | 10:20 PM
Bergus's Avatar
3rd Gear
Yeah, I did the same thing, and the pin would not budge. I can only speculate that somehow the lock release was not engaged when pushed in, but like you, I was very frustrated. I wish I could help more.
Old Sep 17, 2019 | 06:24 PM
bmsmith25's Avatar
Appreciate this thread, as I've been bouncing my head off concrete trying to figure this out. I'm having the same issue described by @Bergus above. I can insert the key, pull the green arm and turn it expecting the pin to fully slide down into the hitch as it's designed to do. 1) when I turn the arm as far as possible, the pin is still sticking out too far to be inserted into the receiver 2) when I let go of the arm and let it sink into the grooves (which based on all the video's I've watch should then stay put until being pushed into the receiver where the small silver lever lets the pin free and hook into the receiver... It seems as though it's stripped and just slips back to the initial position.
I'm trying to figure out if this is a brut force thing w/ the pin or key or something else.
Any further guidance on what's been done to fix. I'm debating buying another hitch, but they're expensive and it's seems many others are having the same issue... Would hate to have 2 very heavy and expensive paper weights.
Thanks!
Brian
me6067
Aug 28, 2017 10:03 PM
rcelik
Jan 26, 2016 03:40 PM
Kalel
Sep 29, 2011 02:22 PM
lmjones1
Oct 12, 2009 09:29 PM
ScottMcc
Apr 9, 2009 08:50 PM
