Really strange engine wiring problem
Old Oct 14, 2022 | 01:03 PM
nura78's Avatar
Default Really strange engine wiring problem
Hi everyone. I recently had some trouble and came across this:
This wire is coming from the firewall and is going to the positive lead to the coil on cylinder #2 (I think)
Could someone explain why anyone would do this?
the wire color in question is blue/white
Old Oct 15, 2022 | 05:24 PM
NJOverland's Avatar
What is it connected to on the other end?
Old Oct 15, 2022 | 06:42 PM
nura78's Avatar
TBH, i'm not sure. It looks like the wire is going into the cabin somewhere.
I did trace the wire to the electrical box on the right, but then it moves past the firewall.
Not sure where to start tracing from there.
Old Oct 16, 2022 | 05:57 PM
tracyc's Avatar
Describing the nature of the trouble you mentioned might help.
Old Oct 17, 2022 | 05:28 AM
nura78's Avatar
When i plug my ODB reader in, the codes coming back say that the valve on cylinder 2 is open 😬
Its definitely not open, otherwise my car would probably not be drivable.
I should also note that the engine light goes on and off periodically, so i'm thinking that the wire in question isn't connected all that well.
Old Oct 17, 2022 | 02:45 PM
tracyc's Avatar
Can you share the exact code you are getting?
Old Oct 17, 2022 | 03:18 PM
nura78's Avatar
The error code i've been getting is P0202.
I should note that this error code has been going on and off intermittently. The wiring connection is really awful. I need to get inside the engine again and take a better picture. of the connection itself.
Old Oct 17, 2022 | 03:27 PM
nura78's Avatar
Who ever did this was an amateur 😬
Old Oct 17, 2022 | 09:31 PM
DakotaTravler's Avatar
P0202 is an injector code, not valve.
Old Oct 17, 2022 | 09:52 PM
nura78's Avatar
Ah ok, looks like you're right. I guess i mis-remembered the code message. I took a picture this time:
