Rear Brake/Marker Bulbs
Old Jun 19, 2016 | 06:04 PM
EastCoast's Avatar
Default Rear Brake/Marker Bulbs
I know that it's recommended to get LR bulbs but does anyone know if there is a Ford equivalent? Part number?
Thanx...
Old Jun 19, 2016 | 07:42 PM
cmb6s's Avatar
I don't know, but I haven't had any problems at all using the long life Philips bulbs available at any auto store.
Old Jun 19, 2016 | 08:51 PM
EastCoast's Avatar
Good to know... is there a certain bulb designation for these two filament bulbs or are they just labelled as two filament?
Old Jun 19, 2016 | 09:22 PM
jafir's Avatar
I've also used parts store bulbs in both of my LR3. I think the issue is you must use the correct bulb by application, not just whatever fits.
Old Jun 20, 2016 | 11:03 AM
DavC's Avatar
Same here, I have used whatever the auto parts store gave me for make/model I provided. No problems
Old Jun 20, 2016 | 11:27 PM
bbyer's Avatar
Default it's a quality control thing re bulbs
The link below has my comments re bulbs. It is really a quality control thing. A bulb sourced from the Mercedes, Volvo, Audi, VW dealer would be OK as perhaps would a brand name bulb from say NAPA.
It is the far east ones to be concerned about as the computers are expecting to see amps and resistances in a given range and that failed filaments will drop downwards and not fall across a second filament.
Look inside thru your red rear plastic tailight lenses and note that the filaments are or should be oriented vertically rather than cross wise. That is not by chance.
DISCO3.CO.UK Photo Gallery - Brake Light Switch Replacement/Land Rover Stop Tail Light dual filament bulb nominal 12 volt 21 / 5 watt filaments
Old Jun 21, 2016 | 11:09 AM
houm_wa's Avatar
idk I've always used the off-brand ones that I get at my local auto parts store and they've been fine. I don't even remember the name on the label. I just make sure that the filaments are oriented correctly when they are installed.
Old Jun 21, 2016 | 11:50 AM
bbyer's Avatar
Default not that much off brand
I would say that if the filaments orient correctly, that the bulbs are not that much "off brand".
It seems there is one factory in what was Yugoslavia that makes all the bulbs for the OEM Euro guys. I suspect that the Euro bulbs that do not quite meet OEM standards get private branding, hence some of the private brands found in the chain stores can be OK. It is the far east manufactured bulbs found in the dollar stores that can be the real problem.
Old Jun 21, 2016 | 07:19 PM
EastCoast's Avatar
I did notice when I picked up a set of Sylvania twin filament, that they only installed one way... they was a long pin and a short pin on the side that could only engage and twist when it was oriented correctly.
Thanx for everyones replies, this forum is truly a wealth of knowledge with users that are passionate and extremely patient and helpful.
Scott R
Jan 6, 2010 11:23 AM
meltdowndave
May 15, 2008 06:07 PM
rsr50
May 11, 2008 01:52 PM
harryballzack
Oct 3, 2007 11:59 AM
khtemple
Sep 10, 2005 06:16 PM
