Rear CV Axle help
martinezparamounttkd@gmail.com (12-29-2021)
Thanks a bunch. I did that and still couldn’t get it all the way in. I was hitting it so hard I bent the end with the screw on it. I ordered another one that should be here in a few days. I had the axle pretty much straight when I was hitting it but maybe not straight enough. I was doing the whole thing by myself. And only had the knuckle attached by the upper control arm to give me more space to work with. I undid the swaybar also for more room and then use a ratchet strap to help lift the bottom of the knuckle up. Maybe I just need someone to help me lift the knuckle/rotor up so I can get a better aligned. I even tried pushing it in with my air hammer and still nothing
i’ve done the front CV axles multiple times and always got pushed in with ease. Taking it out was usually harder haha. thanks!
![Frown](https://landroverforums.com/forum/images/smilies/udbMv2o.png)
handsome rob
09-17-2007 11:16 AM
