Rear Locking Diff Wires
Hi, so yesterday I changed the Rear Differential Fluid on my 08 LR3 (with Locking Rear Diff), and I noticed that the wiring assembly that connects into the Diff was possibly 'damaged', but certainly gives me cause for concern - There's a silver-colored, approx 10mm diameter, 'shroud' that looks to be made of some sort of 'insulation' material, that surrounds the 2 very thin wires, which connect into a plastic connector, which connects into the rear diff. Issue - These 2 wires had a length of approximately 15mm that was not at all protected by anything - It's as if the protecting shroud/tubing has 'split apart' from the plastic connector unit. In any case, it wouldn't take much to snip and damage one or both of these wires. So, I patched it up with electrical tape and a marine heat-shrink tube as best I could, which didn't really help much, so smeared some rubber caulking around the wires, in order to try to provide a rudimentary level of protection. Thoughts? Can I buy a replacement wiring harness? Is it easy to connect? Price? Part number? Do I need to pull apart the whole vehicle to make the connection to the other end? Thanks!
Thanks Unseenone, yeah, good news, no faults or anything weird, so actual wiring and connection is fine. Therefore 100% 'preventative' maintenance. I've given it some more thought, and I think I'll do a 'proper' job with some plastic or metal corrugated electrical tubing - The stuff that is 'cut' (slit) down the middle. I'll use small zip-ties to 'close' them up, one wrapped around the wires. Corrugated because the wires make (almost) a 'right angle' turn in order for the Connector to snap into the housing on top of the Diff. In other words, I need to create a 'protected right angle' housing. Also, if I use this corrugated tubing, I can wrap some insulating material around the wires. Or maybe just pack it with some rubber caulking. Sidenote, I may do the same thing to the various wires that attach to wheels (and near suspension) - ABS Wheel Speed Sensor, Brake Pad Wear Sensor, Ride Height Sensor, etc. Both my Brake Pad Wear Sensors are broken - I did this on my last Off-Road trip. Seems to happen every time I go Off-Road. Thinking that some extra protection wouldn't be a bad idea.
oljohnboy
09-02-2014 02:44 PM
tjp74
11-13-2012 01:11 PM
