Rear Upper Control Arm
Old 12-14-2021, 12:22 PM
lenlayne's Avatar
3rd Gear
Originally Posted by houm_wa
I've got 132k on my 2005 and the rear arms are original. Suspension is tight, like new.
i found a Landrover specialty shop who can do the job both sides for around $2200 not $9500 !!!
horray!
houm_wa (12-14-2021)
Old 10-08-2023, 07:37 PM
Ackrovers's Avatar
4th Gear
My 2006 LR3 rear upper control arm has failed. The two local Rover repair shops have said it’s a big job and one said body must come off frame. It looks like you’re in MA…Who did you use to do the repair for $2200?
Old 10-08-2023, 09:23 PM
houm_wa's Avatar
How have you validated this? What are the physical symptoms?
My '05 has 135k miles and the rear uppers are fine. My '06 has 245k miles and while there is some "noise" coming from the rear suspension, nobody (at either dealer or indie) has stated that the rear uppers look shot. So, how have you determined this?
Old 10-09-2023, 08:22 AM
Ackrovers's Avatar
4th Gear
Default Drivers side rear upper control arm failure
Pictures show crack and rusted out.
Old 10-09-2023, 01:50 PM
houm_wa's Avatar
Yikes!! Thank goodness I live in the Pacific NW.
Ackrovers (10-09-2023)
Old 10-09-2023, 04:57 PM
Ackrovers's Avatar
4th Gear
Yes, These salty New England winters do so much damage. In fact, I just closely inspected the under carriage and I could put a screwdriver through the chassis box steel frame just in front of the spare tire. For whatever reason, that frame section (about 8 inches) rusted through. It's a real shame as the motor only has 100k miles on it and it's never been off road. The body and interior is in great shape. It has been driven by a women driver since 2009.
I wonder what the options are now. To try and patch the steel frame and replace all the rusted suspension and wheel parts? Or, sell it as a parts vehicle?
Old 10-09-2023, 05:12 PM
DakotaTravler's Avatar
I have never seen an LR3 that bad, ever. And I live in Wisconsin, salt rod capitol of the US. That almost looks like a flood salvage.
Old 10-10-2023, 02:42 PM
houm_wa's Avatar
Okay now I'm not sure what the bigger "shame" is, rusty rig with 100k on the engine, or the fact that it's never been offroad!
Ackrovers (10-10-2023)
Old 10-10-2023, 07:30 PM
Ackrovers's Avatar
4th Gear
I know, right? @houm_wa it’s a shame…no off road experience. Check out some more frame rust. I want to now take body off frame, weld in new frame section, rebuild the upper and lower control arms, wheel, hub, brakes etc,, remove all rust and turn it into a fun overlander rig.
Old 10-10-2023, 07:32 PM
I am even more convinced that sat in water, salt water, for an extended period. That is by far the worst LR3 frame I have ever see. Almost be easier to buy a beat up LR3 with a good frame and split that one. Work on the frame, make it nice, transfer your body over - assuming your body is not rusted out too?
Quick Reply: Rear Upper Control Arm
