Recommended Factory Maintenance?
4.4 petrol doesn't have a timing belt. The diesel does. Its every 7,500 miles oil changes with 5W30 synthetic and outside of a rotation and pollen filter every 15k the air filter isnt changed till 60k and the TC and the Electronic rear diff is changed at 75k.
Well that's good news. Is changing the diff fluid and t-case fluid like it is in a NP241 Jeep t-case or a Dana 44? Just pop the cover, inspect for metal shavings, drain the fluid, clean it out with brake cleaner and refill?
Or is it a bit more than a typical fluid flush in a domestic vehicle?
absolutely not, You only change the rear diff at 75k if it has a rear electronic diff. But you remove the drain and let it drain out and then fill it up with special fluid. its special fluid that comes from the dealer.
tjhappel
Feb 20, 2011 07:54 PM
rover2003
Dec 8, 2007 08:40 AM
