Replacing Thermostat Housing
Old Feb 28, 2012 | 04:04 PM
rzuluaga's Avatar
Default Replacing Thermostat Housing
Hi Guys,
after changing the thermostat a couple of weeks ago I am now noticing that the thermostat housing is leaking a bit. I am planning to replace the housing but I am wondering if it is mandatory to drain the coolant as I did it before? or it is not mandatory.. I just want to skip this step if not needed. I do not want to get a mess of coolant fluid when I remove the 3 hoses from the thermostat housing.
Thanks in advance, Roberto
Old Feb 28, 2012 | 04:18 PM
unseenone's Avatar
I am not clear on the subject, but I believe the system is pressurized. You probably do not have to completely drain the system.
For posterity sake, when you change a thermostat, replace the housing, they are notorious for cracking, leaking, and so on. Perhaps a metal replacement might be a good aftermarket piece, I am not available of one besides the OEM one.
Old Dec 18, 2015 | 11:54 AM
rzuluaga's Avatar
Adding a new reference with pictures to help others
Reference
LR3 thermostat housing replacement - Defender Source
Enjoy Roberto
ChefGabe
May 21, 2013 06:28 PM
tgarnick
Jan 8, 2013 12:13 AM
Trickymonk
Apr 25, 2012 10:45 AM
Travelor
Jul 8, 2011 09:58 AM
heromanLSU
Nov 4, 2009 12:09 PM
