Rough Idle, System too lean Bank 1 &2
Alright, I just recently replaced my thermostat housing, and literally upon driving out of the shop i started to notice a rough idle, at first just when in park, but now when in drive at a stoplight. My first thought was to replace the plugs, clean MAF & throttle body, but now im throwing codes for System too lean for both bank 1 &2. I also have cat deficiency codes for cat 1 &2 as well. What should i tell my mechanic to look at first? THANKS!!
PLEASE make sure to reset the system before you get too far down the road trying to diagnose this. I had the same issues (almost exactly) after removing the TB to clean and also install the T-Stat housing and went through a living hell trying to diagnose those codes. Once I finally reset the system with the IIDTool, all was good. It needed to relearn the Throttle Body.
bcolins
Sep 22, 2008 11:53 AM
