rpm fluctuation while driving
Old May 17, 2019 | 06:45 PM
mtaylo32's Avatar
How difficult was replacing that?
Old May 17, 2019 | 07:10 PM
DakotaTravler's Avatar
Literally directions in the first reply to this post.
Old May 17, 2019 | 08:25 PM
mtaylo32's Avatar
Saw that, was just curious. Thanks.
Old May 21, 2019 | 12:29 PM
Anyway to reset fuel adaptations? If you can and the issues is gone, then it may lean towards something like MAF/O2, etc. If you and the problem persists I would expect something like a throttle position sensor, etc. Something with absolute valves gone afoul.
Old Mar 20, 2021 | 03:02 PM
Frank key's Avatar
Default App sensor
Originally Posted by AndrewGr
Thanks Savannah. After three years and investing several thousand dollars into other potential fixes - your suggestion solved the problem. No more RPM fluctuation. It's gone. Fixed! I cannot believe that replacing the gas pedal assembly (which includes a new APP sensor / gas pedal position sensor) finally solved the problem. Thank you so much!
Hi, did this also fix the small kick when coming to a stop? Thanks, Frank
Old Mar 20, 2021 | 05:28 PM
AndrewGr's Avatar
After a few weeks of driving, all the issues reappeared, I gave up and sold it. It had to be the torque converter in the transmission all along.
Old Mar 18, 2022 | 10:40 AM
josevoigt's Avatar
Hi
When the car is making this rpm fluctuation, the motor temperature is working in the panel?
Old Mar 20, 2022 | 09:39 AM
tracyc's Avatar
A couple years ago, I had occasional rpm fluctuations, same as described. I thought I might have a serious problem, but it was completely fixed with a fluid/filter change and a proper refill.
Old Mar 21, 2022 | 07:38 AM
josevoigt's Avatar
Hi
On my car, make RPM fluctuation, the motor temperature didn`t mark, automatic gear box didn´t work properly . . . .and the guilty was only the temperature sensor in the gear box, broken, no connection.
After I shunt the two pins, all work perfectly.
Old Aug 29, 2022 | 09:51 PM
toofaroffroad's Avatar
Default Rpm fluctuation
Hello, experiencing the same issue with my truck. Was going to look into switching out the gas pedal sensor but I noticed my truck does not fluctuate when I’m in manual mode only in automatic. I’m assuming this would rule that fix out?
