RPM Fluctuations
Old Jan 14, 2013 | 12:45 AM
ggs's Avatar
ggs
4th Gear
Default RPM Fluctuations
I have a 06 LR3 with 51k on the odometer. Today after a filling the gas tank the RPM's will drop to 500 after coming to a full stop and then go back up to 750. This problem does not happen when i put the car in neutral and then come to a full stop. Is this a problem with low transmission fluid, and or a torque converter problem? Any help is appreciated!
Old Jan 14, 2013 | 05:18 PM
threalassmikeg's Avatar
I would recommend you clean the carbon from throttle body and plate.
Old Jan 14, 2013 | 06:12 PM
LR Techniker's Avatar
Ditto the above post. Might be the easiest and cheapest fix you ever experience.
Old Jan 14, 2013 | 06:35 PM
ggs's Avatar
ggs
4th Gear
Thanks! I will do that tonight and see what it does.
Old Jan 15, 2013 | 12:03 AM
ggs's Avatar
ggs
4th Gear
Replaced the air filter, cleaned the MAF sensor, and did a through cleaning of the throttle body. Put back together and it runs much better. Picture of the carbon that was removed attached.
Old Feb 2, 2013 | 11:42 PM
TElam's Avatar
I also can attest to this being a fix for the problem. I finally got around to doing this tonight after a month of procrastination and my idle issue getting worse and worse. Not only did cleaning the MAF and throttle body fix the idle issue but now I have noticeably more power. Never ignore maintenance!
Old Feb 4, 2013 | 01:53 PM
mx468's Avatar
Default Throttle body dirty?
I need to do this myself. I've notice the stop and go engine rpm fluctuation. It drops down to 500 than goes to 700. If I stop and go quickly, the engine/truck lurches forward. If I completely stop and wait a second i'm fine. Does this sound like my throttle body is dirty?
Old Feb 4, 2013 | 07:55 PM
TElam's Avatar
Sounds like a good place to start. I never had the bucking forward when coming to a stop, but since this action is maintenace(and easy) anyway, it wont hurt to do it
Old Feb 7, 2013 | 11:25 PM
mx468's Avatar
Default Finally!
Finally cleaned my MAF sensor, throttle bottle(man it was dirty) and I changed my air filter. Truck runs much better, idle doesn't go below 600 rpms when I stop and the engine has much more noticeable pick up. What a easy job and I'm glad I finally did it right before this big blizzard we're suppose to be getting in the NorthEast!
MyRoversNameIsCarl
Feb 16, 2015 04:46 PM
AUSlro
Jun 16, 2008 04:10 AM
Taipan
Freelander
Jan 20, 2007 06:40 PM
jaybe_2
Aug 7, 2006 12:26 AM
pedro tomas
Feb 8, 2006 10:36 PM
