Salutare LR 3
Old Mar 4, 2025 | 07:45 AM
DanielToma's Avatar
Default Salutare LR 3
Cand incerc sa fac o depasire sau sa merg mai repde imi intra in avarie ,nu se mai accelereaza....dupa ce o opresc,,astept sa treaca erorile...o pornesc si merge..dar trebuie sa merg cu ea foarte incet..daca accelerez mai tare intra iar in avarie....mentionez ca atunci cand motorul este rece,masina merge ok...dupa ce se incalzeste incepe sa faca figuri...
Old Mar 4, 2025 | 10:31 AM
douglastic's Avatar
Since this is a US-based site, I'm afraid you might have a hard time getting help here with the language barrier.
Google Translate from Romanian:
When I try to overtake or go faster, it crashes, it doesn't accelerate anymore...after I turn it off, I wait for the errors to pass...I start it and it runs...but I have to drive it very slowly...if I accelerate harder, it crashes again...I should mention that when the engine is cold, the car runs ok...after it warms up it starts to act up...
We need to know what engine you have, and the error codes.
Google Translate to Romanian:
Trebuie să știm ce motor aveți și codurile de eroare.
Deoarece acesta este un site cu sediul în SUA, mă tem că s-ar putea să vă fie greu să obțineți ajutor aici cu bariera lingvistică.
Old Mar 4, 2025 | 08:53 PM
loanrangie's Avatar
Being in Europe i suspect its a TDV6 in which case you need to check the inter-cooler for cracks and hoses for splits, also check the EGR function and the seals in the intake piping.
As above reading the DTC codes is the best way forward after visual inspections.
Arrancadasoft
Dec 1, 2022 01:39 PM
Cellina Cellina
Mar 4, 2016 03:52 AM
klandrover
Sep 13, 2015 11:33 AM
SOONERRN
Apr 28, 2008 11:06 PM
