Soon to be owner with questions
Old Oct 5, 2007 | 04:55 PM
pherplexed's Avatar
Default Soon to be owner with questions
Woohoo! About to purchase an '07 HSE and just had some last minute questions. I'm totally new to Land Rover, coming over from an '03 Grand Cherokee Limited.
Ok, so here's what I'm wondering:
1) Do you HAVE to use premium gasoline with the LR3? Shouldn't mid-grade be ok? Does gasoline grade really make a difference for any car, for that matter?
2) I love the way my Jeep displays tire pressure with the actual PSI numbers next to each wheel on a diagram of the car. How does the LR3's system work? I never saw it on the one I test drove.
3) Does the rear/front park assist also have a visual indicator to go along with the tones?
4) I'm wondering about iPod integration. I've got iPod integration on my jeep (lets me use the factory radio controls / steering wheel controls to control the iPod, and I love it! I know the LR3 doesn't come with it, but I'm seeing Land Rover sells an add-on kit. Is anyone using one and is it worth the dough?
5) Potentially dumb question, but my wife said the front headreast was uncomfortable and wanted to know if they move. Do they?
That's all I have for now. Thanks for any answers...I'm STOKED!
Old Oct 5, 2007 | 09:22 PM
Max_A6's Avatar
Default RE: Soon to be owner with questions
1) You don't have to, but it's recommended. Yes, it makes a difference, and no, you won't save much by using cheaper gas.
2) Beeps when pressure is low
3) No
4) Dunno, factorystereo plays MP3s and that's good enough for me.
5) They don't move.
Old Oct 5, 2007 | 09:32 PM
pherplexed's Avatar
Thanks for the info. So does the tire pressure monitor system actually indicate which tire is low or do you have to just get out and look?
Old Oct 6, 2007 | 12:54 PM
AZLR3's Avatar
You will need to get out and look.
Regarding the IPod - there is an aux input jack on the back of the center console. All you need is a 3.5mm plug to plugaudio cable to connect the IPod to theradio. Press the AUX buttontwice on the radio and you can listen to your IPod.
Congratulations onyour new LR3
Old Oct 7, 2007 | 06:40 AM
You do have to run high octane, not mid grade, it has been that way for Rovers for years.
Old Oct 10, 2007 | 11:44 AM
jimbiram's Avatar
For awhile, I ran every other tank with Premium and Mid-grade. Have since determined that the premium gives better mileage, and engine doesn't struggle on the hills. Stick to Premium...
Run33
May 11, 2015 09:43 PM
rockanomicon
Jan 2, 2008 10:23 AM
discoBunit
May 8, 2007 03:21 PM
sammyboy
Feb 8, 2006 10:57 AM
jarmstrong
Apr 30, 2005 03:38 AM
