Spacers
Old Sep 26, 2020 | 09:25 PM
Coop05's Avatar
Default Spacers
I just put coil springs on with +2, but I need a couple more inches .
i have larger tires on it and it fit fine before I conversed over.
Its a lr3 and I’m having hard time finding the spacers I need
Old Sep 26, 2020 | 09:30 PM
how big are the tires you went with?
This will get you more height however just using the spacers since you are a coiler.
https://lucky8llc.com/products/proud...346f9994&_ss=r
Old Sep 26, 2020 | 09:32 PM
Coop05's Avatar
Had 275/55/20 on for 2 years and they fit fine, went to coil springs and now they rub
Old Sep 26, 2020 | 09:43 PM
Those should clear. Can you tell where it's rubbing?
Old Sep 26, 2020 | 09:44 PM
Coop05's Avatar
Rubbing front Wheel well
Old Sep 26, 2020 | 09:46 PM
I had a slight rub with a slightly larger tire it was the inner front edge I just trimmed the liner and it wasn't an issue anymore. Mine only rubbed when backing up and turning
azjagster
Range Rover L405 (Fourth Gen)
Aug 8, 2020 06:19 PM
elboy0712
Nov 5, 2017 11:07 AM
ycc456
Apr 2, 2014 12:38 PM
ZGPhoto
Jul 1, 2013 02:28 PM
ZGPhoto
Mar 19, 2013 11:32 AM
