Strange Cylinder Misfire
Old Jan 22, 2022 | 06:33 PM
MadMex's Avatar
8th Gear
Default Strange Cylinder Misfire
My 2005 LR3 V6 has a cylinder 3 misfire. It misfires at idle, misfire counts go up between 800-900 RPM's, and completely go away at over 1,100 RPM's...... what is going on with cylinder 3? Truck is perfectly drivable at high RPM's, except when RPM's are low for extended periods of time, like at red lights and stop and go traffic, then the Reduced Engine Performance kicks in.
any help would be appreciated.
Old Jan 23, 2022 | 10:54 AM
Blackngold77's Avatar
My money is on the ignition coil dying.
Also check all wiring is tight and not damaged
Old Jan 24, 2022 | 10:32 AM
douglastic's Avatar
Swap #3 coil with another cylinder - see if the issue moves, or stays at #3
Old Jan 24, 2022 | 12:35 PM
tracyc's Avatar
Misfires often go away at higher rpms
Old Jan 24, 2022 | 04:03 PM
MadMex's Avatar
8th Gear
I believe it's a mechanical issue because I did a engine compression check by cranking and checking amps on battery; there is definitely a dip in amps drawn on cylinder 3.... a LR repair shops recommended a engine swap for over $6,500.... I just don't get that when the engine runs so good on the freeway or high RPM's over 1,200 ...
I'm guessing there is a timing issue, a bad teeth or chain, or cam shaft.... how would I test these?
thanks
Old Jan 24, 2022 | 04:57 PM
tracyc's Avatar
Yeah I'd swap coil and plug on the bad cylinder and see if the problem moves, assuming that hasnt been done yet. But why did the LR shop say it needed an engine swap?
Old Jan 24, 2022 | 05:10 PM
MadMex's Avatar
8th Gear
because they couldn't figure out the problem, they said they did compression check, and leak down tests, and all checked out....
Old Jan 24, 2022 | 05:20 PM
tracyc's Avatar
Hmm, I would hope they would have already done the simple things like check plugs and coils then....
Old Jan 24, 2022 | 05:29 PM
MadMex's Avatar
8th Gear
yes, I already did all that, parts swaps, problem stays the same...
Old Jan 24, 2022 | 05:37 PM
tracyc's Avatar
So you said there was a "dip in amps drawn on cylinder 3" right? Do you mean you were monitoring the ignition circuit on cyl. 3 and saw some kind of voltage drop there that you didn't see on the other cylinders? If so, that would lead me to believe it's not a mechanical but an electrical issue... But maybe I misunderstood what you were saying.
