Struggles Going Uphill
This will be a bit of a story but I'll try to put some cliff notes in. Bought our LR3 back in December and have had a few problems since, but the three persisting problems are:
To make matters more fun, I have no codes, CEL or transmission faults. And haven't thrown a code since I've owned it.
I spoke to another specialist who also agreed that the head gasket seemed unlikely to be causing the power loss and thought it could be as simple as a fuel pump, dirty throttle body or the transmission. The vehicle had the mechatronics service prior to my purchase and I just did it again, but the hard downshifts and power loss persist. With the mechatronics service I used ZF fluid and reset the adaptations using a GAP tool, and since then it seemed to do better uphill, but the car also down shifted to first and rev'd fairly high.
Has anyone else experienced a similar issue?
Also for reference here is what I have already done to the vehicle.
- Trouble going up a steep hill, around an 8% grade
- Hard downshift from 5-4
- Vibration under load, but I think this is from the rear driveshaft bearing support, already plan to tackle this
- Replaced t-stat, water pump, bleeder tee, coolant bottle, leaking hoses (I think I had 3)
- Replaced heater core, it was completely clogged and I have heat again yay!
- Replaced front diff, it was grinding and upon disassembly the bearings were shot
- Transfer case
- Spark plugs
- PCV valve
- All fluids, diffs, coolant, oil, brake, trans, etc.
- Serp belts
- Cabin and engine air filter
Yea new solenoids from California Transmission and I cross referenced them with to the transmission sticker on the side. I also replaced the pan and filter, bridge seal, connector seal and those 4 other seals (B clutch, C clutch, D1, D2).
And hopefully the thermostat isn't bad. I'd be surprised if it was since the vehicle doesn't overheat after driving for an hour on the highway. Also the part I purchased was from the OE supplier on FCP and came with the t-stat and a new sensor installed.
