sunroof screen clip
Old 10-18-2013 | 09:31 PM
ljdiscovery's Avatar
Default sunroof screen clip
I have searched but no luck. When I bought our LR3, the second row sunroof screen was open. I didn't check it and didn't give it much of a thought. While detailing the truck last weekend, I noticed that the screen wouldn't stay shut. The second row sunroof screen locking clip tab is broken. The part that is mounted to the front under-edge of the sunroof frame. The clip on the screen is good. Is there a way to replace the tab? Is there a place to buy one? Thanks Phil
2005 LR3 HSE Tonga Green and Alpaca Interior
Old 10-18-2013 | 09:56 PM
jafir's Avatar
I don't know if this is the part you need or not: EGT500060LUM
Old 10-18-2013 | 10:35 PM
roverguy7's Avatar
Are you sure it's broken?
There is a known issue with the tensioner that holds the blind clip in place when closed, see attached.
Old 10-19-2013 | 11:02 PM
it looks like the clip that attaches to the headliner on the front edge of the glass turned up and thus the catch for the blind/screen won't catch. I may need to replace the part that attaches to the headliner. Does anyone know how it is secured to the headliner? It feels like ther may be some plastic screws of some sort. Thanks in advance. This is a great forum. Thankfully I don't need to use it nearly as often as I used the DII forum........Phil
Old 10-20-2013 | 09:46 AM
roverguy7's Avatar
Will it latch in place if you push up on the headliner right where it secures?
If so, I would suggest the repair in the bulletin.
jmillerau
06-24-2012 11:25 AM
DonRW2007
05-30-2012 07:55 AM
BigRed98
06-21-2010 01:30 AM
Disconoobie
11-10-2007 09:49 PM
tap121
Sights N Sounds
04-25-2007 02:28 AM
