sunroof screen clip
Old Oct 18, 2013 | 08:31 PM
ljdiscovery's Avatar
Default sunroof screen clip
I have searched but no luck. When I bought our LR3, the second row sunroof screen was open. I didn't check it and didn't give it much of a thought. While detailing the truck last weekend, I noticed that the screen wouldn't stay shut. The second row sunroof screen locking clip tab is broken. The part that is mounted to the front under-edge of the sunroof frame. The clip on the screen is good. Is there a way to replace the tab? Is there a place to buy one? Thanks Phil
2005 LR3 HSE Tonga Green and Alpaca Interior
Old Oct 18, 2013 | 08:56 PM
jafir's Avatar
I don't know if this is the part you need or not: EGT500060LUM
Old Oct 18, 2013 | 09:35 PM
roverguy7's Avatar
Are you sure it's broken?
There is a known issue with the tensioner that holds the blind clip in place when closed, see attached.
Old Oct 19, 2013 | 10:02 PM
it looks like the clip that attaches to the headliner on the front edge of the glass turned up and thus the catch for the blind/screen won't catch. I may need to replace the part that attaches to the headliner. Does anyone know how it is secured to the headliner? It feels like ther may be some plastic screws of some sort. Thanks in advance. This is a great forum. Thankfully I don't need to use it nearly as often as I used the DII forum........Phil
Old Oct 20, 2013 | 08:46 AM
roverguy7's Avatar
Will it latch in place if you push up on the headliner right where it secures?
If so, I would suggest the repair in the bulletin.
jmillerau
Jun 24, 2012 10:25 AM
DonRW2007
May 30, 2012 06:55 AM
BigRed98
Jun 21, 2010 12:30 AM
Disconoobie
Nov 10, 2007 08:49 PM
tap121
Sights N Sounds
Apr 25, 2007 01:28 AM
